Simple Java Programme does not compile in V50
Hallo,
the very simple java programme below works in version 4.4 of Comsol but not with version 5.0.
There are no error messages, but the class-file is not generated.
I run (on Linux):
comsol compile test.java
Did anybody run into the same problem and found a solution?
Thanks in advance.
Regards
Jens
import java.io.*;
import com.comsol.model.*;
import com.comsol.model.util.*;
public class test{
public static void main(String[] args) throws Exception {
run();
public static Model run() throws Exception{
Model model = ModelUtil.create("Model");
model.param().set("Laenge","4.6[m]");
return model;
2 Replies Last Post 25.03.2015, 03:18 GMT-4
Posted: 1 decade ago 24.03.2015, 11:36 GMT-4
I run (on Linux):
Because of a bug introduced in 5.0, you have to provide the absolute path to the file. E.g., something like
comsol compile /home/jensk/test.java
This bug will be fixed in the upcoming 5.1 release.
[QUOTE]I run (on Linux): comsol compile test.java[/QUOTE] Because of a bug introduced in 5.0, you have to provide the absolute path to the file. E.g., something like comsol compile /home/jensk/test.java This bug will be fixed in the upcoming 5.1 release.
Posted: 1 decade ago 25.03.2015, 03:18 GMT-4
Thanks Gunnar, that does the trick.
I hope another problem is also contained in the upcoming fix:
Unfortunately my colleagues introduce space in directory names. In that case the path will not be treated correctly. E.g
comsol compile "/home/jens/Project 42/test.java"
will complain about no existing "/home/jens/Project".
But I can work around by placing java files in a non-space place.
Regards
Jens
Thanks Gunnar, that does the trick. I hope another problem is also contained in the upcoming fix: Unfortunately my colleagues introduce space in directory names. In that case the path will not be treated correctly. E.g comsol compile "/home/jens/Project 42/test.java" will complain about no existing "/home/jens/Project". But I can work around by placing java files in a non-space place. Regards Jens
