Non linear conductivity in AC
I need to simulate the behavior of a dielectric material in AC to obtain the electric field distribution.
Normally I would use the Electrostatics study, but this material has a nonlinear dependence of the conductivity with the electric field, and the Electrostatics physic doesn't takes in account the influence of conductivity.
I tried to use the Electric currents study with a sinusoidal voltage source and a time dependent solver. The problem is, it takes a lot of time even for a 2D model.
Do you have any ideas on how to improve it? ( or even if my assumptions are wrong, I'm not absolutely sure if EC+time solver is the best model for my problem)
Thank You
3 Replies Last Post 24.03.2015, 10:08 GMT-4
Posted: 10 years ago 23.03.2015, 09:30 GMT-4
Bernardo,
you could try a stationary parametric sweep with the voltage as parameter.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Bernardo, you could try a stationary parametric sweep with the voltage as parameter. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 10 years ago 24.03.2015, 04:55 GMT-4
Edgar,
Thank you for your answer. The problem is, after I need to take in account the influence of temperature and, for some levels of conductivity, also the charge density. That's why I wanted to go with an temporary solver.
Regards
Bernardo
Edgar, Thank you for your answer. The problem is, after I need to take in account the influence of temperature and, for some levels of conductivity, also the charge density. That's why I wanted to go with an temporary solver. Regards Bernardo
Posted: 10 years ago 24.03.2015, 10:08 GMT-4
Bernardo,
ok, then you probably have to keep the time dependent study. You may still try to optimize the solver. Mostly a direct solver is faster than an iterative one, but needs more memory. The nonlinear method under the 'Fully coupled' node can also have a big impact on convergence. Check different nonlinear methods. Check the convergence plot. Sometimes using linear discretization can really speed up a model, but you have to check if accuracy is sufficient. As you are after the electric field, being a spatial derivative, linear elements are probably not a good advice, because the field gets discontinuous. But you can try.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Bernardo, ok, then you probably have to keep the time dependent study. You may still try to optimize the solver. Mostly a direct solver is faster than an iterative one, but needs more memory. The nonlinear method under the 'Fully coupled' node can also have a big impact on convergence. Check different nonlinear methods. Check the convergence plot. Sometimes using linear discretization can really speed up a model, but you have to check if accuracy is sufficient. As you are after the electric field, being a spatial derivative, linear elements are probably not a good advice, because the field gets discontinuous. But you can try. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
