Edgar J. Kaiser
Certified Consultant
10 years ago
16.03.2015, 19:28 GMT-4
Miao,
there might be a chance to help you if you either specify your problem in a more detailed way or (better) upload your model. Clear meshes and solutions to keep it small enough.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Miao,
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
10 years ago
17.03.2015, 11:30 GMT-4
Hi Edgar,
Thanks for your reply. I have attached my model.
Thank you very much in advance and please let me know if you have any questions.
Miao
Miao,
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Hi Edgar,
Miao
[QUOTE]
Miao,
Cheers
Edgar
Edgar J. Kaiser
[/QUOTE]
Edgar J. Kaiser
10 years ago
18.03.2015, 05:15 GMT-4
Hi Miao,
I meshed your model with default settings and didn't see any problem.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Hi Miao,
Cheers
Edgar
Edgar J. Kaiser
10 years ago
18.03.2015, 10:14 GMT-4
Hi Edgar,
Could you explain briefly how you meshed the model? I am learning to use COMSOL
Miao
Hi Edgar,
Miao
Edgar J. Kaiser
10 years ago
18.03.2015, 10:39 GMT-4
Choose the Mesh tab in the menu bar and click Add Mesh. There are many options of course, but the default setting already generates a mesh. Now you can play with element sizes, shapes, structured mesh options, etc. Meshing is a wide field. You will have to invest some time in playing with the options.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Cheers
Edgar
Edgar J. Kaiser
9 years ago
12.06.2015, 16:36 GMT-4
Hi Edgar,
I am able to get the impedance plot now, but if I put the PZT in air, I can get a clean and nice plot, but if I put PZT in water the impedance plots, both real and imaginary are very noisy. Do you have any ideas why this is happening?
I created a small PZT and put it into a larger block with water. Defined the top surface as terminal with voltage of 1V and bottom surface as ground. Gave the damping loss as 1/Qm=0.013 and dielectric loss of 0.02. ran the simulation and added a 1D plot group, then plotted the real impedance by expression as real(1/acpz.Y11) and the imaginary part as imag(1/acpz.Y11).
Do you see any problem with my method?
Thank you very much for your help.
Miao
Hi Edgar,
Miao
