Boundary Integration factor of 1000 different
If I perform a boundary integration through the PostProcessing > Boundary Integration menu on an outlet velocity, v, I get -2.428152e-9 [L/s]. Then if I then goto Options > Integration Couplings > Boundary Variables and enter VolFlow as the Name, v as the Expression and 4 as the Integration Order. Then in Global Expressions I create a variable called VolF which equals VolFlow.
I run the simulation and perform a boundary integration using the first method the result is -2.428152e-9 [L/s]. If I then look at the value of VolFlow from the PostProcessing > Global Variables VolF = -2.428152e-12
Why is there a factor of 1000 difference?
Tom
1 Reply Last Post 31.08.2009, 16:09 GMT-4
Posted: 2 decades ago 31.08.2009, 16:09 GMT-4
it could be because 1000 Liters = 1 m^3. The default unit system is SI so your boundary integration result for volumetric flow rate would be in m^3/s which is 1/1000 of flow rate in L/s
