Mesh the volume between two mapped surfaces
Posted 05.03.2015, 05:01 GMT-5 RF & Microwave Engineering, Mesh Version 5.0 4 Replies
Is there any way to generate volume elements between two mapped surfaces? Please, find the minimal simulation file attached.
In the end I would like to have one domain (the inner block) meshed with cubes, and it should be connected with prism/pyramid elements to the triangular boundary of the outer block.
I've tried to make both surfaces (of the outer and inner block) mapped surfaces with the same distribution of elements and then sweep between them. No luck.
On the other hand I can convert both mapped surfaces to triangular meshes and then generate Free Tetrahedrals between them, but this is NOT what I want, because the inner block ends up with 5 as many elements as it could.
Any ideas appreciated.
Bartek Chaber
Bartek Chaber
4 Replies Last Post 05.03.2015, 13:44 GMT-5
