Initial Stress
Posted 30.05.2010, 11:58 GMT-4 3 Replies
Hello All,
I had (and still have) a problem with COMSOL and tried to explain it to the support staff. I describe the problem below:
I am trying to model the effect of residual (tensile) stress in a fully clapmed circular membrane. The membrane is deflected by a torque applied to an inclusion at the center. Because of symmetry, I modeled a quarter of the membrane and used parametric solver to see the effect of the variable stress on the mode shape (please see the attached file). I entered the value for sigma_x and sigma_y in "intial stress" page of the subdomain settings. Now
- As you can see (postprocessing menu>Domain Plot Parameters>Line/Extrusion> plot the z-deflection for boundaries 2 and 8) the deflection curves are irregular at the boundaries. Why is that?
- It seems the membrane is getting more flexible which is counter intuitive. If the value of the sigma is positive does it mean a tensile or compresive stress in Comsol?
The answer I got was:
Unfortunately, it is not really physically accurate to have a constant initial stress. What happens is that the initial stress is not consistent with the boundary conditions and the interface between the softer and the stiffer material. This causes the solution to be somewhat strange. The solution is also mesh dependent; You will see that if you refine the mesh, the solution will be different.
Also, the deformation due to the initial stress is of the same magnitude as the deformation due to the torque. Thus, the increased deformation of the pre-stressed situation is not due to softening, but rather a superposition of the two deformations. You can see this by removing the torque completely and solving for just the initial stress.
Well, I would like to see if anyone actually has a suggestion to solve this problem.
Nima
Nima
3 Replies Last Post 20.06.2010, 13:47 GMT-4
