DC discharge - Undefined value found in the stiffness matrix
Hi everyone,
I’m trying to solve a time-dependent study on a DC discharge 2d model. I inserted some fictitious boundaries in the geometry in order to facilitate the creation of a mapped mesh, but when I try to compute the study the following error occurs:
Undefined value found.
- Detail: Undefined value found in the stiffness matrix.
There are 1000 equations giving NaN/Inf in the matrix rows for the variable comp1.En.
at coordinates: (0.00101,4.3275e-005), (0.00101,2.625e-005), (0.00103,4.3275e-005), (0.00103,2.625e-005), (0.00105,4.3275e-005), ...
and similarly for the degrees of freedom, NaN/Inf in the matrix columns.
I think that BC and meshing are well defined, in fact the model is successfully solved if the fictitious boundaries are not inserted in the geometry and a free triangular mesh is used. But I would prefer to use a mapped mesh. Can someone help me?
2 Replies Last Post 02.02.2015, 10:59 GMT-5
Posted: 1 decade ago 02.02.2015, 04:59 GMT-5
Maybe I solved the problem by marking the fictitious bondaries as mesh control edges.....
Luke Gritter Certified Consultant
Posted: 1 decade ago 02.02.2015, 10:59 GMT-5
Chiara,
When using the finite volume formulation, internal boundaries in the plasma region cause this error. The technique you mentioned is a good way to get around the problem.
Luke Gritter
AltaSim Technologies
Chiara, When using the finite volume formulation, internal boundaries in the plasma region cause this error. The technique you mentioned is a good way to get around the problem. -- Luke Gritter AltaSim Technologies
