How to use COMSOL to solve problems with dimensionless time and distance but not conventional t and x???
In my model, I need to transfer the conventional mathematical model into dimensionless one. For example, transfer t into ι=t*u/n/L . Then I have to draw picture with dimensionless distance and time. How can I achieve that ???
The picture like one of the the COMSOL conference paper by Ben Niu?????
Thank you?
6 Replies Last Post 27.01.2015, 02:55 GMT-5
Posted: 1 decade ago 26.01.2015, 07:10 GMT-5
You can define any variable or their combination in the plot definitions.
In the main window of Comsol model you can select the unit system; there is also a dimensionless option.
Lasse
You can define any variable or their combination in the plot definitions. In the main window of Comsol model you can select the unit system; there is also a dimensionless option. Lasse
Posted: 1 decade ago 26.01.2015, 07:13 GMT-5
Hello Lasse:
Thank you very much for your technical help. I'll try it.
Shirley
Hello Lasse: Thank you very much for your technical help. I'll try it. Shirley
Posted: 1 decade ago 26.01.2015, 07:24 GMT-5
Hello Lasse,
I have modified the model with the method you told me, but there is still some problems.
I want to repeat the model in this paper and make some improvements, draw the relations between c and dimensionless time.
Can you tell me how to achieve that??? Thank you very much.
Shirley
Hello Lasse, I have modified the model with the method you told me, but there is still some problems. I want to repeat the model in this paper and make some improvements, draw the relations between c and dimensionless time. Can you tell me how to achieve that??? Thank you very much. Shirley
Posted: 1 decade ago 26.01.2015, 09:45 GMT-5
What's the problem? Reading the paper takes some effort...
Lasse
What's the problem? Reading the paper takes some effort... Lasse
Posted: 1 decade ago 26.01.2015, 20:17 GMT-5
Get a relationship curve between concentration C and dimensionless time . But in the model the default is conventional time t, even I set the unit system to be non in the main surface.
Posted: 1 decade ago 27.01.2015, 02:55 GMT-5
You need to make a global plot:
Results --> 1D Plot Group --> Global --> x Axis Data --> Parameter: Expression
There you can put your dimensionless time.
Wish this helps
Lasse
You need to make a global plot: Results --> 1D Plot Group --> Global --> x Axis Data --> Parameter: Expression There you can put your dimensionless time. Wish this helps Lasse
