Geometry - positioning new objects using existing points
When positioning newly created geometric objects in a workplane is it possible to directly use measured data points for position points? For example, say I have an existing square in a workplane, I create a new square, and I want that new square's corner to be at the same position as one of the corners of the existing square. I can use the measure tool to find the position of the corner of the existing square and manually enter that data into the position fields of the new square, but is there anyway to do this without having to manually find the position data and copy and paste it into the new position fields? When positioning a new object, I want to be able to click on existing point of my geometry and have that data populate the position fields of the new object.
Hopefully my explanation makes sense. Thank you.
1 Reply Last Post 10.12.2014, 01:58 GMT-5
Posted: 1 decade ago 10.12.2014, 01:58 GMT-5
I do not know of any way, this is a "feature" I have suggested for quite some years, but it seems difficult to implement, because usually COMSOL are good to introduce our suggestions.
But perhaps if we are more to send a suggestion mail to support it might arrive once.
But in the geometry we have at least the "measure" so with a few clicks its possible to catch the values, but its not very efficient when one have many points to catch.
When doing hand drawings of shapes, normally there is a "snap" on existing points in the geoemtry
It the same for the graphs in the post processing, it would be nice to be able to click copy/paste values of curves
Hi I do not know of any way, this is a "feature" I have suggested for quite some years, but it seems difficult to implement, because usually COMSOL are good to introduce our suggestions. But perhaps if we are more to send a suggestion mail to support it might arrive once. But in the geometry we have at least the "measure" so with a few clicks its possible to catch the values, but its not very efficient when one have many points to catch. When doing hand drawings of shapes, normally there is a "snap" on existing points in the geoemtry It the same for the graphs in the post processing, it would be nice to be able to click copy/paste values of curves -- Good luck Ivar
