Undefined value error with Scattering Boundary Condition
Posted 25.11.2014, 07:38 GMT-5 RF & Microwave Engineering, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.4 2 Replies
Dear all,
I try to set up an eigenfrequency simulation for an optical nanostructure, where its eigenmodes and corresponding Q-factors should be simulated. To do so, an air cylinder with scattering boundaries is placed around the structure. This method was already used in our research group with Comsol 3.5a, where it perfectly worked. If I try this in the same way as before in Comsol 4.4 I get an error that says that some undefined values where found (I put the complete error at the end).
Even if I take an working mph-file from 3.5a and load and rerun it in 4.4 I get this error.
To demonstrate it, I created a smaller simulation in Comsol 4.4 that should just calculate the optical eigenmodes of a silicon disk. It is attached to this message.
I know that I could also use a PML around the simulation volume (which I already did and which works), but in my particular case I would like to use a scattering boundary. You find the complete error at the end of this message.
Thank you.
Hannes
Undefined value found.
- Detail: Undefined value found in the stiffness matrix.
There are 4992 equations giving NaN/Inf in the matrix rows for the variable comp1.E10.
at coordinates: (1.95739e-006,4.10639e-007,1.5e-006), (1.93312e-006,5.12863e-007,1.5e-006), (1.33784e-006,1.48666e-006,1.5e-006), (1.2579e-006,1.55489e-006,1.5e-006), (1.31557e-006,1.3701e-006,1.5e-006), ...
There are 1664 equations giving NaN/Inf in the matrix rows for the variable comp1.E20.
at coordinates: (1.23741e-006,1.44043e-006,1.5e-006), (1.27943e-006,1.26486e-006,1.5e-006), (1.52137e-006,1.29824e-006,1.40898e-006), (1.4484e-006,1.23084e-006,1.5e-006), (1.85009e-006,7.59702e-007,1.40843e-006), ...
There are 1664 equations giving NaN/Inf in the matrix rows for the variable comp1.E21.
and similarly for the degrees of freedom, NaN/Inf in the matrix columns.
- Feature: Eigenvalue Solver 1 (sol1/e1)
Thank you.
Hannes
2 Replies Last Post 22.12.2014, 07:13 GMT-5
