Inquiry about how to put constraint on PDE dependent variable
Dear All,
I am carrying a simulation of 3 coupled PDEs (coefficient form PDEs).
One of the PDE (Diffusion-drift equation) is of a dependent variable representing the ion concentration which can't be negative according to its physical definition.
So I am wondering is there a way to implement a constraint of that PDE that will prevent the dependent variable from going negative.
Thanks in advance for your kindly help.
1 Reply Last Post 11.11.2014, 21:30 GMT-5
Posted: 1 decade ago 11.11.2014, 21:30 GMT-5
In addition, the simulation will fail if a single point on the mesh is of a negative ion concentration. (I believe it is because the coupled equation could not converge in this scenario.) Once a negative ion concentration presents, the time-step of the PDE solver will keep on decreasing till the failure message displayed.
Such a failure seems could not be overcame by tuning the damping factor of the newton's method.
My current solution of preventing the negative ion concentration from happening is to add a background initial ion concentration for the corresponding PDE. However, doing so is not physical.
Could any one with the same experience advise on such an issue.
In addition, the simulation will fail if a single point on the mesh is of a negative ion concentration. (I believe it is because the coupled equation could not converge in this scenario.) Once a negative ion concentration presents, the time-step of the PDE solver will keep on decreasing till the failure message displayed. Such a failure seems could not be overcame by tuning the damping factor of the newton's method. My current solution of preventing the negative ion concentration from happening is to add a background initial ion concentration for the corresponding PDE. However, doing so is not physical. Could any one with the same experience advise on such an issue.
