help! error about bandgap_photonic_crystal model.
Hello All?
when run the bandgap_photonic_crystal example in RF model,the following error maybe appear at times.
Error:
Failed to find a solution for all parameters,
even when using the minimum parameter step.
Not all parameter steps returned.
Warning: New constraint force nodes detected: these are not stored !
25 1e-005 1.0000000 1.5e-005 126 111 229
total waring 115
And the Hz is in red color in physics> scaler variable. I think this is the place of key problem. Who know why
Thank you in advance.
Yaohui Zhan
3 Replies Last Post 09.05.2013, 03:21 GMT-4
Posted: 1 decade ago 22.04.2010, 02:50 GMT-4
the "red" units are warnings, but in 3.5a (and earlier) not all functions permit to transmit units, so this might be OK (typically integration coupling variables do not transfer units correctly).
i can only suggest to go through your model, step by step, there is most probably a "click" missing somewhere ;)
Have fun Comsoling
Hi the "red" units are warnings, but in 3.5a (and earlier) not all functions permit to transmit units, so this might be OK (typically integration coupling variables do not transfer units correctly). i can only suggest to go through your model, step by step, there is most probably a "click" missing somewhere ;) Have fun Comsoling Ivar
Posted: 1 decade ago 22.04.2010, 10:59 GMT-4
Thanks very much for your reply. It's Ok when I go through another time. The problem is due to a wrong formula input. And the red unit of Hz still exist and surely has no effect on the right result.
Best wishes!
Thanks very much for your reply. It's Ok when I go through another time. The problem is due to a wrong formula input. And the red unit of Hz still exist and surely has no effect on the right result. Best wishes!
Posted: 1 decade ago 09.05.2013, 03:21 GMT-4
I have the same question when run the bandgap_photonic_crystal example in RF model.
.Can you leave your e-mail for convenient communication.
Aichao Yang
[QUOTE] Hi I have the same question when run the bandgap_photonic_crystal example in RF model. .Can you leave your e-mail for convenient communication. Aichao Yang
