Two Phase Fluid Flow Convergence Error half-way into solution
Posted 29.09.2014, 12:59 GMT-4 Fluid & Heat, Microfluidics, Mesh, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers 0 Replies
Time dependent solver for Laminar Two-Phase Flow, Level Set crashes half-way through the solution with error message "last time step didn't converge". Do you know what could cause this? The geometry is a simple y-junction. The mesh is user controlled and done by creating distributions (rectangular) and sweeping them.
Hello Melaku Wol
