Shorting one end of three cables
I want to simulate the experiment I do in the lab. I have one ends of 3 cables energized from 3 phase source while the other ends are shorted. I am running 2D simulation, therefore, does anyone have idea how can I short one ends of the cables in 2D?
Akim
8 Replies Last Post 22.09.2014, 00:34 GMT-4
Posted: 1 decade ago 17.09.2014, 00:50 GMT-4
You can use the Electric Circuit, see the attached example.
Dima.
Dima Apter
A2Z Consulting Ltd.
www.a2z-consulting.com
Hi, You can use the Electric Circuit, see the attached example. Regards, Dima. -- Dima Apter A2Z Consulting Ltd. www.a2z-consulting.com
Posted: 1 decade ago 17.09.2014, 21:17 GMT-4
Dear Dima,
Thank you so much! I wonder what are External I Vs. U 1, Eormsxternal I Vs. U 2 and External I Vs. U 2 for? Are they for current waveforms or something else?
Akim
Dear Dima, Thank you so much! I wonder what are External I Vs. U 1, Eormsxternal I Vs. U 2 and External I Vs. U 2 for? Are they for current waveforms or something else? Best, Akim
Posted: 1 decade ago 17.09.2014, 23:56 GMT-4
And also what is the difference between External U Vs. I 1 and External I Vs. U 1?
Thank you!
And also what is the difference between External U Vs. I 1 and External I Vs. U 1? Thank you!
Posted: 1 decade ago 18.09.2014, 00:41 GMT-4
"External I vs. U" connects between the FEM coil and the spice circuit.
If you open Help window within COMSOL and then click on the feature node you will get the following:
"The External I vs. U feature connects an arbitrary voltage measurement (for example, a circuit terminal or circuit port boundary or a coil domain from another physics interface) as a source between two nodes in the electrical circuit. The resulting circuit current from the first node to the second node is typically coupled back as a prescribed current source in the context of the voltage measurement."
Dima Apter
A2Z Consulting Ltd.
"External I vs. U" connects between the FEM coil and the spice circuit. If you open Help window within COMSOL and then click on the feature node you will get the following: "The External I vs. U feature connects an arbitrary voltage measurement (for example, a circuit terminal or circuit port boundary or a coil domain from another physics interface) as a source between two nodes in the electrical circuit. The resulting circuit current from the first node to the second node is typically coupled back as a prescribed current source in the context of the voltage measurement." -- Dima Apter A2Z Consulting Ltd. www.a2z-consulting.com
Posted: 1 decade ago 18.09.2014, 00:43 GMT-4
I greatly appreciate your help!
Posted: 1 decade ago 18.09.2014, 13:09 GMT-4
S
S
Posted: 1 decade ago 18.09.2014, 20:10 GMT-4
Dear Dima,
Can you help me also in the following matter? My cables have metallic (aluminum) sheath and they are bonded at both ends and grounded, thus resulting in circulating currents in the sheaths. I wonder how can I model these circulating currents in the sheaths in Electrical circuits interface? Since these currents are induced and voltage between the two ends of sheaths is zero (or negligible) I cannot model them as current source or voltage source, right? Can current controlled current source be used to define sheath circulating currents?
Thanks!
Akim
Dear Dima, Can you help me also in the following matter? My cables have metallic (aluminum) sheath and they are bonded at both ends and grounded, thus resulting in circulating currents in the sheaths. I wonder how can I model these circulating currents in the sheaths in Electrical circuits interface? Since these currents are induced and voltage between the two ends of sheaths is zero (or negligible) I cannot model them as current source or voltage source, right? Can current controlled current source be used to define sheath circulating currents? Thanks! Regards, Akim
Posted: 1 decade ago 22.09.2014, 00:34 GMT-4
Probably you do not need the Electric Circuit in this case. You can try the following:
1. Build the sheaths as separate domains.
2. Define them as additional Single-Turn Coil.
3. Select "Voltage" in the "Coil Excitation" and set it zero.
Check if it will work for you.
Best Regards,
Dima.
Dima Apter
A2Z Consulting Ltd.
Probably you do not need the Electric Circuit in this case. You can try the following: 1. Build the sheaths as separate domains. 2. Define them as additional Single-Turn Coil. 3. Select "Voltage" in the "Coil Excitation" and set it zero. Check if it will work for you. Best Regards, Dima. -- Dima Apter A2Z Consulting Ltd. www.a2z-consulting.com
