need help
hi I want to simulate magnetic field around a multi turn coil with different core shapes. please help mee
1 Reply Last Post 27.08.2014, 07:07 GMT-4
Posted: 10 years ago 27.08.2014, 07:07 GMT-4
A good starting point for modelling fields from multi turn coils is given in the following:
www.comsol.com/model/single-turn-and-multi-turn-coil-domains-in-3d-14067
If the models you want to run are stationary, then the above should be all you need. If you are looking at time dependant models, there are a few other considerations that need to be made. I am far from an expert, but will try and help if you have further questions!
A good starting point for modelling fields from multi turn coils is given in the following: http://www.comsol.com/model/single-turn-and-multi-turn-coil-domains-in-3d-14067 If the models you want to run are stationary, then the above should be all you need. If you are looking at time dependant models, there are a few other considerations that need to be made. I am far from an expert, but will try and help if you have further questions!
