16.04.2010, 01:47 GMT-4
your model is not that easy to understand, I had to turn off the surface rendering to better see it. If I understand correctly what puzzles me is that your ALE surface 9,10,18,25 is supposed to move along u,v,w, but it's attached to the lower (-Z) surface area that si fixed.
It looks like you have overconstrined your ALE, but I'm not 100% sure I have got right all the details of you model
Now I do not have enought time to go into details of your model, mixing 3 physics requires some undestanding and study, buzt I would suggest you start with a 2D axi case and a pure Z motion, this is quicker to set up and easier to debug, and then you port it to 3D
Have fun Comsoling
Have fun Comsoling
17.04.2010, 15:13 GMT-4
I've followed your advice and simulated the thing on a simplified 2d axially simmetric model for now.
Do you know how can I plot the results in 3D?
17.04.2010, 15:51 GMT-4
for many cases this is possible, but the technique requires some work, there are a few examples in the doc, you need to use the "extrusion coupling variables", check the doc.
To be honest, I find it too long so I hardly use this approach as its only for a visualisation (in my cases so far, but can be also successfully used to port i.e. initial conditions to 3D) and the 2D is anyhow sufficient for me.
But once a model is running nicely in 2D, I often make it fully in 3D, with a coarser mesh mostly, otherwise I would have to wait a year for the PC to finish, for global check and for the presentation, when ttat is important.
Have fun Comsoling
Have fun Comsoling
