large 3D electromagnetic problem
I have to simulate a 3D electromagnetic model, the wavelength is 400nm, the dimension of the model is 1um*1.5um*3um cuboid. of curse it has different layers in this cuboid, let's say it has 3 layers with refractive index respectively, 1.5, 2, 4.
I used the GMRES together with geometric multigrid preconditioner. but it didn't converge.
does anyone have some experiences in modeling 3D optical device?? Can you give me some suggestions?
Regards
Honghui
6 Replies Last Post 05.05.2010, 09:18 GMT-4
Posted: 1 decade ago 17.04.2010, 03:56 GMT-4
Any success yet? In a few days time, I am also going to start working on 3D problems and would then need to figure out a way with iterative solvers.
Any success yet? In a few days time, I am also going to start working on 3D problems and would then need to figure out a way with iterative solvers. Thanks
Posted: 1 decade ago 17.04.2010, 04:08 GMT-4
what is your device (solar cell or LED?). Did you checked all of the boundary conditions?
Posted: 1 decade ago 17.04.2010, 04:39 GMT-4
It's a solar cell.
as for the boundary condition, I use PMC and PEC because there are some periodic structure.
have you simulated some 3D stuffs?
It's a solar cell. as for the boundary condition, I use PMC and PEC because there are some periodic structure. have you simulated some 3D stuffs?
Posted: 1 decade ago 17.04.2010, 04:40 GMT-4
not yet,:(
not yet,:(
Posted: 1 decade ago 17.04.2010, 06:22 GMT-4
do not forget to do a search on the forum several subvjects have already been discussed, you might find good clues there too
Have fun Comsoling
Hi do not forget to do a search on the forum several subvjects have already been discussed, you might find good clues there too Have fun Comsoling Ivar
Posted: 1 decade ago 05.05.2010, 09:18 GMT-4
I have simulated 3D structures in COMSOL. There are clues and dedicated chapter for 3D RF simulations which i found very helpful in the RF user guide. Maybe you would like to check there as there are plenty of parameters that need to be adjusted for a successful run. If you cannot find helpful info let me know.
