Hello Amr Al Abed
9 years ago
12.09.2015, 13:05 GMT-4
I have the same question regarding all the variants for `sweeps`. Does anybody know the difference between them?
7 years ago
18.05.2017, 06:45 GMT-4
I am also puzzled by this question. anyone knows the difference?
Walter Frei
COMSOL Employee
7 years ago
18.05.2017, 14:08 GMT-4
A parametric sweep is performed within the COMSOL Multiphysics GUI, so you have to have the software up and running.
A batch sweep is the same as a parametric sweep, but you simply run the software from the command line, without the GUI. Functionally, is is equivalent to the parametric sweep, it will take the same time to do a batch sweep as a parametric sweep. For details on this, please see:
www.comsol.com/blogs/how-to-run-simulations-in-batch-mode-from-the-command-line/
You can also launch a batch sweep from within the GUI itself, and keep working within the GUI. For details on this, please see:
www.comsol.com/blogs/the-power-of-the-batch-sweep/
A cluster sweep is only available if you're using a Floating Network License type (
www.comsol.com/products/licensing) and lets you solve on a cluster. That is, different nodes of the cluster will be solving different parameters, in parallel. So, a parametric sweep (or batch sweep) run on a single computer would solve all of the different sweep values sequentially (say 1000 different parameters, one after another.) A cluster sweep could distribute those 1000 different parameters onto, e.g. 100 different nodes, solving only 10 parameters on each cluster node, in parallel. This would cut total runtime by ~100-fold.
https://www.comsol.com/blogs/how-to-run-simulations-in-batch-mode-from-the-command-line/
You can also launch a batch sweep from within the GUI itself, and keep working within the GUI. For details on this, please see: https://www.comsol.com/blogs/the-power-of-the-batch-sweep/
A cluster sweep is only available if you're using a Floating Network License type (https://www.comsol.com/products/licensing) and lets you solve on a cluster. That is, different nodes of the cluster will be solving different parameters, in parallel. So, a parametric sweep (or batch sweep) run on a single computer would solve all of the different sweep values sequentially (say 1000 different parameters, one after another.) A cluster sweep could distribute those 1000 different parameters onto, e.g. 100 different nodes, solving only 10 parameters on each cluster node, in parallel. This would cut total runtime by ~100-fold.
Edgar J. Kaiser
Certified Consultant
7 years ago
18.05.2017, 18:31 GMT-4
Walter is that correct? Shouldn't a small model run faster in a batch sweep? E.g. we have four parameter values, we allow 4 parallel processes on a 4 core machine and allow 1 core per process?
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
[QUOTE]
Functionally, is is equivalent to the parametric sweep, it will take the same time to do a batch sweep as a parametric sweep. [/QUOTE]
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
