Failed to find a solution. Divergence of the linear iterations. Returned solution is not converged.
Mahesh MS by Research
Module: AC/DC, Study: Frequency Domain
Sir/Ma'am,
I have modelled a coil which scans the surface of a sample material for any superficial cracks. For this, i have introduced a small crack and also i have modelled the coil along with a ferrite bobbin.
The coil is scanned for a distance of 50 mm in steps of 1 mm for crack detection. So during scanning exactly at the vicinity of the crack (where the bobbin meets the crack), the solution do not converge.
Mesh used: Crack, Coil and Bobbin - Extra fine and the remaining area are fine mesh.
Frequency Used: 100 Hz (Low frequency)
Solvers used: Iterative-> 1. FGMRES - In this the solution oscillates around a particular value after 50-60 iterations.
2. BiCG - The relative tolerance in the convergence plot is monotonically increasing with very huge values of the order of e15.
Direct-> MUMPS: Failed to find a solution. The relative error (8) is greater than the relative tolerance.
All this happens only at the vicinity of the crack and in the other scan locations, i get a converged solution.
If the coil and bobbin size are doubled, we get a converged solution through all the sweep points.
I am attaching the mph file for your reference.
Mahesh
0 Replies Last Post 13.07.2014, 16:16 GMT-4
Hello Mahesh
