Composites. Thermoset resin cure kinetics
Dear all,
I am new to Comsol and interested in working on composites. I would like to simulate the kinetics of epoxy resin cure, and the evolution of the resin properties with temperature and degree of cure . Unfortunately I don't know how to begin with this. The geometry is a disc and I have started with the heat transfer module and introducing my own kamal equation for the cure kinetics.
Can someone help me with cure modeling of composites?. I am not even sure if the model is well built because non-linear solver did not converge when I make the compute.
I would be grateful if someone can help me with some references/suggestions/examples etc. Did someone already build a similar model??
Thank you.
2 Replies Last Post 10.08.2015, 21:27 GMT-4
Hello Cristina Monteserin
Posted: 1 decade ago 11.08.2014, 09:43 GMT-4
I am also interested in modelling something similar to Christina's in comsol. I want to simulate the coupled thermal and cure kinetics problem for a thermoset composite. Can you give me any advice or examples? Thank you in advance.
Hello, I am also interested in modelling something similar to Christina's in comsol. I want to simulate the coupled thermal and cure kinetics problem for a thermoset composite. Can you give me any advice or examples? Thank you in advance.
Posted: 10 years ago 10.08.2015, 21:27 GMT-4
hi, I'm also new for the thermoset. Can we make friends and learn each other.
