Meshing with a parametric sweep
I work with Comsol 4.4 solid mechanics.
I would like to compute a parametric sweep on a geometrical parameter, namely, the thickness of a material.
As this thickness varies from 0.2 mm to 1.5 mm, while the material piece is 30 cm long (looks like a plate), I have some trouble with the meshing : in order to keep a reasonnable number of elements in this material, I need to build really long and thin tetrahedric elements (at least far away from the area of interest). It's difficult to do, but I can manage to do it when the thickness of my material is fixed.
The problem is, when I try to compute the parametric sweep, it cannot compute a proper mesh for all the values of my thicknesses.
Is there a way to adapt the mesh to the different steps of my parametric sweep ? Maybe to define a mesh by hand for each step of the sweep ? Or is there any option for that kind of situations ?
Thank you !
Astrid Billon.
1 Reply Last Post 18.06.2014, 09:39 GMT-4
Posted: 1 decade ago 18.06.2014, 09:39 GMT-4
Astrid,
you could try to parameterize the meshing as well, i.e. add geometry dependent scaling parameters to the mesh definitions.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Astrid, you could try to parameterize the meshing as well, i.e. add geometry dependent scaling parameters to the mesh definitions. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
