Edgar J. Kaiser
Certified Consultant
09.06.2014, 15:40 GMT-4
Michael,
you have a couple of problems in your model:
- There is no air domain around the coil
- Numerical coils need to have a constant cross section along the winding path (the corners in the rectangular shape of your coil violate that)
- An automatic current calculation subnode with insulation and input definition is needed
Refer to 'multiturn_coil_asymmetric_conductor' model in the model library to get the details.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Michael,
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
09.06.2014, 16:51 GMT-4
I have looked at the model in the library that you referenced but I am still a bit confused. I remade my model to have a constant cross section and I also thought that I surrounded the coils with an air domain. I think that I put in the current calculation subnode in the cross sectional area but it doesn't work like the library model.
Edgar J. Kaiser
10.06.2014, 02:48 GMT-4
There aren't any study steps in the new model you attached. Look into the example once more. You need a current calculation step and a stationary (in your case?) or frequency domain step.
Also giving a small conductivity to the air domain can be useful for solver stability. Sometimes also the Gauge Fixing for A-field is required to get the solver stable.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Cheers
Edgar
Edgar J. Kaiser
10.06.2014, 11:58 GMT-4
Thanks! I have gotten my model working a lot better by following your advice. I am curious as to weather I could model how the magnetic field in the coils would change through time as the coils were pulsed with current. I didn't find an example model that demonstrated this phenomena.
31.10.2014, 09:36 GMT-4
I'm new at COMSOL and I'm looking to study the magnetic field in between two rectangular coils. It seems that your model is a good start for me. Is it possible to share your last version of the model that works better according to your last post?
Thanks.
Thanks.
9 years ago
27.12.2015, 17:27 GMT-5
hello Edgar J3. Kaiser I have a problem in the simulation of a coil in a pulsed excitaion you can please me helped by a model
