Why Comsol solution is mesh dependent?
I tried to solve the following simple 1D problem by COMSOL.
du/dx=-u
u(x=0)=1
u(x=1)=0
1D Comsol PDE gives a solution which is mesh dependent! If you refine the mesh, you get a different solution in 1D domain.
By the way. this is a simple 1st order ODE has general solution, u=A*exp(-u). It only has one arbitrary constant. How does Comsol deal with two point BCs in this particular case?
Thanks for your help.
Guodong
4 Replies Last Post 10.04.2010, 01:05 MESZ
Posted: 2 decades ago 06.04.2010, 04:17 MESZ
I haven't tried working in 1D yet, but aren't you seeing a basic property of the finite element method here?
In 2D graphing, for instance, if you try to fit a higher order curve solution with a finite number of lower order elements, then the solution will change with the number of elements. It's like plotting a complex curve using short straight line segments: the more segments, the better fit.
If you had an exponential order 1D element, it would solve your problem with any arbitrary number of elements.
I took a quick look at the elements available and I see linear, quadratic, .... up to quintic. No exponential there. I think you're stuck with mesh dependent solutions.
Maybe I'm missing something in your question, but I learned a little from thinking about it anyway.
-Jeff
I haven't tried working in 1D yet, but aren't you seeing a basic property of the finite element method here? In 2D graphing, for instance, if you try to fit a higher order curve solution with a finite number of lower order elements, then the solution will change with the number of elements. It's like plotting a complex curve using short straight line segments: the more segments, the better fit. If you had an exponential order 1D element, it would solve your problem with any arbitrary number of elements. I took a quick look at the elements available and I see linear, quadratic, .... up to quintic. No exponential there. I think you're stuck with mesh dependent solutions. Maybe I'm missing something in your question, but I learned a little from thinking about it anyway. -Jeff
Posted: 2 decades ago 06.04.2010, 09:31 MESZ
the problem you describe dont have a solution [ "not well posed" ] but comsol dont know that this is why he try and provide "garbage".. this is the old wisdom
Garbage in -> Garbage out :-)
JF
the problem you describe dont have a solution [ "not well posed" ] but comsol dont know that this is why he try and provide "garbage".. this is the old wisdom Garbage in -> Garbage out :-) JF
Posted: 2 decades ago 06.04.2010, 17:54 MESZ
ditto -
your BC u(x=1)=0 cannot be satisfied with the DE. Another way to look at it is this- You have a first order DE but two BC's thus the problem is overspecified and not well posed.
ditto - your BC u(x=1)=0 cannot be satisfied with the DE. Another way to look at it is this- You have a first order DE but two BC's thus the problem is overspecified and not well posed.
Posted: 2 decades ago 10.04.2010, 01:05 MESZ
just wanted to point out that if the second boundary condition satisfied the solution...
i.e. analytic solution was Ae^-x and based on boundary 0, A was equal to unity...
then inserting u(x=0)=1 and u(x=1)=e^(-x)
in this manner your second boundary condition satifies the DE.
just wanted to point out that if the second boundary condition satisfied the solution... i.e. analytic solution was Ae^-x and based on boundary 0, A was equal to unity... then inserting u(x=0)=1 and u(x=1)=e^(-x) in this manner your second boundary condition satifies the DE.
