Magnetic flux density (streamlines) and current density by cylindrical condutors
I am trying to plot magnetic flux density (streamlines) and current density produced by cylindrical conductors shown in the attached file, for dc and ac (e.g. 50 Hz) cases. But there is a problem occurs when I click on 'compute' and comsol becomes irresponsive,
I would very happy if someone will help me in this matter.
Akim
2 Replies Last Post 07.04.2015, 06:32 GMT-4
Hello Akim Borbuev
Posted: 1 decade ago 07.04.2015, 06:22 GMT-4
I think you should first define a boundary. Also, use the "Magnetic Field" study and not the "Magnetic Field Formulation" .
Use a Single Turn coil and I hope it will work after that. If you have a 3d geometry where the conductors follow a coil like path, use 2-d axisymetric :)
I hope this helps.
Anup
I think you should first define a boundary. Also, use the "Magnetic Field" study and not the "Magnetic Field Formulation" . Use a Single Turn coil and I hope it will work after that. If you have a 3d geometry where the conductors follow a coil like path, use 2-d axisymetric :) I hope this helps. Regards, Anup
Posted: 1 decade ago 07.04.2015, 06:32 GMT-4
You can check this out. :)
