Difference solutions between importing wavelength and frequency
I study on the model of step-index-fiber, the solution is for importing the wavelength of 1.55 um. When I change the parameter to corresponding frequency( Specify wave using has already changed ), effective mode index is different from that of importing wavelength. It is supposed to be the same. I am confused for the two different solutions. Which one is the correct solution?
Thank you for reply at first.
Huang Lili
0 Replies Last Post 24.03.2014, 23:46 GMT-4
Hello 莉莉 黄
