Upper and Lower Constraints or limits on variables
I have a model I am trying to run involving the concentration of hydrogen in zirconium and it keeps dropping below 0 in some spots and above 1 in others... It solves several PDE's one of which is the Cahn-Hilliard equation for the conserved Hydrogen concentration. Is there a way to constrain the variable or set limits where it will not go above or below certain points?
4 Replies Last Post 15.11.2016, 21:02 GMT-5
Hello Jake Bair
Posted: 1 decade ago 08.05.2014, 04:07 GMT-4
If you are using a segregated solver, you can use "lower limit" to avoid the concentration dropping below zero. For an upper limit I am also looking for a solution...
Posted: 1 decade ago 09.06.2014, 09:51 GMT-4
I am having the same issue. I am working with a different module (Subsurface Flow Module with Richards' equation) and I need to set an upper limit on the dependent variable, which in my case is water pressure. At t=0 water pressure over a certain boundary is negative; when its value reaches 0 I want to keep it constant, so basically I need to set 0 as upper limit.
Has anyone found a solution for this issue? I would greatly appreciate any help.
Alessia
Hi, I am having the same issue. I am working with a different module (Subsurface Flow Module with Richards' equation) and I need to set an upper limit on the dependent variable, which in my case is water pressure. At t=0 water pressure over a certain boundary is negative; when its value reaches 0 I want to keep it constant, so basically I need to set 0 as upper limit. Has anyone found a solution for this issue? I would greatly appreciate any help. Thanks Alessia
Posted: 1 decade ago 07.08.2014, 17:17 GMT-4
My solution is to change the equation, so I calculate "-u" instead of "u". Thus when you set lower limit for -u, that's the upper limit for u, then you can use "-(-u)" in your model as the original variable.
This still doesn't solve the problem if you want to set lower and upper limits at the same time though.
My solution is to change the equation, so I calculate "-u" instead of "u". Thus when you set lower limit for -u, that's the upper limit for u, then you can use "-(-u)" in your model as the original variable. This still doesn't solve the problem if you want to set lower and upper limits at the same time though.
Posted: 8 years ago 15.11.2016, 21:02 GMT-5
Hi, this is indeed the problem, one cannot set both the lower and upper limits. I am wondersing if comsol has any solution for this at this moment? Thanks in advance,
lailai
[QUOTE] My solution is to change the equation, so I calculate "-u" instead of "u". Thus when you set lower limit for -u, that's the upper limit for u, then you can use "-(-u)" in your model as the original variable. This still doesn't solve the problem if you want to set lower and upper limits at the same time though. [/QUOTE] Hi, this is indeed the problem, one cannot set both the lower and upper limits. I am wondersing if comsol has any solution for this at this moment? Thanks in advance, lailai
