Flow through a concentric annulus
I have some problems for the simulation of a simple flow trough a concentric annulus.
I use an axisymmetric model in which only the annular duct is defined (the model is attached here).
Then, for the study of the laminar flow in the channel, I impose as boundary conditions no slip at walls, a non-zero inlet pressure (P_in = 50 kPa) and a zero pressure for the outlet.
I already performed a similar analysis for a flow between parallel plates, obtaining results in agreement with the analitical model of Poiseuille Flow.
Considering the fact that the annular duct is narrow, I would expect results similar to the case of flow between parallel fixed plates, but when I try to solve the model the following error message appears.
"Failed to find a solution.
Returned solution is not converged."
Although the pressure seems quite high, I have already checked that even for lower values I always have the same problems, even if I increase the max number of iterations.
Can someone help me to understand where is the error in my model?
3 Replies Last Post 17.09.2014, 21:58 GMT-4
Posted: 1 decade ago 22.11.2013, 08:00 GMT-5
Hi Daniel,
Your outlet condition is not assigned to any boundary...
Hi Daniel, Your outlet condition is not assigned to any boundary... Jeff
Posted: 1 decade ago 22.11.2013, 08:57 GMT-5
Hi Jeff,
Thank you for your quick reply and... sorry for the post. I was sure to have correctly set the outlet boundary condition.
Thanks again.
Daniel.
Hi Jeff, Thank you for your quick reply and... sorry for the post. I was sure to have correctly set the outlet boundary condition. Thanks again. Daniel.
Posted: 1 decade ago 17.09.2014, 21:58 GMT-4
Have you ever solved this problem? I meet the same problem, and do not find a way to solve it.
