Piezoelectric material properties
I am using a piezoelectric material in my modeling. I know Young's modulus, density, Poisson's ratio and dielectric co-efficient of the piezoelectric material. However, I do not know how to find the required values such as Elasticity matrix, Coupling matrix and Permittivity matrix to give as input in COMSOL in the stress-charge form.
For your information, I am considering the material as isotropic.
If anybody knows how to calculate, please help me.
Kiran
2 Replies Last Post 15.11.2013, 17:26 MEZ
Posted: 1 decade ago 15.11.2013, 14:31 MEZ
Kiran,
these are material properties. You cannot calculate them, you need to take them from a datasheet or measure them.
If you don't have these data I would recommend to start with one of the predefined materials in the material library. And btw. piezoelectric materials aren't isotropic, they are polarized some way that is reflected by the coupling and permittivity matrices.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Kiran, these are material properties. You cannot calculate them, you need to take them from a datasheet or measure them. If you don't have these data I would recommend to start with one of the predefined materials in the material library. And btw. piezoelectric materials aren't isotropic, they are polarized some way that is reflected by the coupling and permittivity matrices. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Alberto Garcia-Cristobal
Posted: 1 decade ago 15.11.2013, 17:26 MEZ
HI
You just need to google . There are many theoretical and experimental data .
If you are working with III–V compound you can have a lot at
scitation.aip.org/content/aip/journal/jap/89/11/10.1063/1.1368156
HI You just need to google . There are many theoretical and experimental data . If you are working with III–V compound you can have a lot at http://scitation.aip.org/content/aip/journal/jap/89/11/10.1063/1.1368156
