Hot Water Tank Model
I am trying to model a hot water tank via COMSOL: A tank filled with hot water, cold water comes in on the side of the tank at the bottom, and the hot water moves out the top. I then want to look at the temperature after a period of time.
I would think that I would need to run the Laminar Flow, and Heat Transfer in Fluids physics programs simultaneously, however, this seems to be giving me errors. Can I not run both physics models together? Or is it that I am just too green at this still?
Paul
1 Reply Last Post 05.11.2013, 07:29 MEZ
Posted: 1 decade ago 05.11.2013, 07:29 MEZ
Hi.
Maybe this link can help you on your problem. You can learn something from their works.
www.comsol.com/community/forums/fluid-flow/thread/20613/
Good luck.
Hi. Maybe this link can help you on your problem. You can learn something from their works. http://www.comsol.com/community/forums/fluid-flow/thread/20613/ Good luck.
