07.10.2013, 22:26 GMT-4
how about this:
1. right-click results>data sets>solution 1(if solution 1 includes the deformed geometry's solution), click remesh deformed configuration.
2. right-click meshes>deformed configuration, click export to file.
3. select file type and insert filename path.
4. click export.
5. right-click geometry, select import.
6. choose the file you exported in 4.
done!!!
how about this:
4. click export.
done!!!
08.10.2013, 12:53 GMT-4
hi TAE,
many thanks for the reply.
but for some reason when i try it,i still get same undeformed geometry after exporting it.
can you name or point an example of that kind so that i ca go through?
once again thanks
hi TAE,
once again thanks
11.10.2013, 00:32 GMT-4
I uploaded test.zip file.
In test.mph file, there are two Models. One is the moving mesh and structural mechanics, another is heat transfer.
after solving the first model, i exported test.mphtxt using the procedure I mentioned before.
and then,
I imported it in the geometry section. you can find the geometry that is deformed.
thanks
and then,
thanks
11.10.2013, 01:20 GMT-4
hi TAE,
i cannot open the zip file you attach.
can you attach it again please.
many thanks
hi TAE,
many thanks
11.10.2013, 04:05 GMT-4
I attached test.mph file.
thanks.
Note : If you want to get a deformed geometry, you need to setup the moving mesh interface.
thanks.
14.04.2014, 20:29 GMT-4
how about this:
4. click export.
done!!!
Hi, Tae,
Thanks for this instruction, it works in GUI. Do you know the matlab script for the steps 2-4.
I tried to implement the export of deformed geometry automatically but can not find the matlab script.
Hope you can still reach this post~
[QUOTE]
how about this:
4. click export.
done!!!
[/QUOTE]
Hi, Tae,
06.11.2014, 17:56 GMT-5
Hi, I have the same problems.
Could you find the Matlab script for exporting the deformed geometry?
Please share to me if you got this.
Thanks very much.
Thanks very much.
Gerardo E. Villarreal-Garcia
10 years ago
01.09.2015, 09:05 GMT-4
Thanks Tae! This was extremely useful!
Gerardo Villarreal
PhD Student
Centre for Quantum Photonics
H.H. Wills Physics Laboratory
University of Bristol
Tyndall Avenue
Bristol
BS8 1TL, UK
Office 1.25
Email: Gerardo.VillarrealGarcia@bristol.ac.uk
Gerardo Villarreal
PhD Student
Tyndall Avenue
Bristol
BS8 1TL, UK
Office 1.25
