how to change material properties of a mesh element in a loop
I am working with livelink to maltab and I have a geometry with three domains assigned with certain material properties. After solving my model for the first iteration, I take the results for each node or element and depenting on the values I get I need to change the material properties of that node or element.
I think that I can't use somehow the command
model.material('<mat tag>').selection.set([<point>]) e.g. for each point node, since the materials are assigned to domains, geometries or boundaries, right?
Do you have any idea about how to make it? For each iteration maybe I have to re-create the geometry including a new domain (even if this is an element) and then assign the domain with the new material properties? how can I create a new domain from matlab?
2 Replies Last Post 16.01.2015, 11:26 GMT-5
Hello Maria Vavva
Posted: 1 decade ago 17.06.2014, 02:32 GMT-4
Hi Maria,
have you found any solution to your problem yet? I have been looking for ages how to do the same thing as you described!
Stefan
Hi Maria, have you found any solution to your problem yet? I have been looking for ages how to do the same thing as you described! Regards, Stefan
Posted: 1 decade ago 16.01.2015, 11:26 GMT-5
Have either of you found a solution? I am trying to change the property values for each individual element. I am currently able to create an interpolation function based on element values and the property I want to assign to individual mesh elements (in my case hydraulic conductivity). This code runs, but the assigned hydraulic conductivities are assigned to different elements than the model I input to the interpolation function.
Some sample code:
"model.file.create('res2');
model.func.create('int1', 'Interpolation');
model.func('int1').set('importedname','test_hyd_cond_elems.csv');
model.func('int1').set('modelres', 'res2');
model.func('int1').set('importedstruct', 'Spreadsheet');
model.func('int1').set('importeddim', '1D');
model.func('int1').set('sourcetype', 'model');
model.file('res2').resource('test_hyd_cond_elems.csv');
expre = 'int1(meshelement)';
model.physics('dl').feature('smm2').set('K', {expre; '0'; '0'; '0'; expre; '0'; '0'; '0'; expre});"
Thank you in advanced for you help,
Carolyne Bocovich
Have either of you found a solution? I am trying to change the property values for each individual element. I am currently able to create an interpolation function based on element values and the property I want to assign to individual mesh elements (in my case hydraulic conductivity). This code runs, but the assigned hydraulic conductivities are assigned to different elements than the model I input to the interpolation function. ... Some sample code: "model.file.create('res2'); model.func.create('int1', 'Interpolation'); model.func('int1').set('importedname','test_hyd_cond_elems.csv'); model.func('int1').set('modelres', 'res2'); model.func('int1').set('importedstruct', 'Spreadsheet'); model.func('int1').set('importeddim', '1D'); model.func('int1').set('sourcetype', 'model'); model.file('res2').resource('test_hyd_cond_elems.csv'); ... expre = 'int1(meshelement)'; model.physics('dl').feature('smm2').set('K', {expre; '0'; '0'; '0'; expre; '0'; '0'; '0'; expre});" Thank you in advanced for you help, Carolyne Bocovich
