Displacement no symmetric
Hi there,
I modelled a simple beam under axial load (20N). The strain and stress values are matching with the theoretical results. But there is no symmetry in the displacement results. The displacement is not coming same on both the ends.
Please correct me.
Model attached.
Naveet.
1 Reply Last Post 01.08.2013, 14:15 GMT-4
Josh Thomas Certified Consultant
Posted: 1 decade ago 01.08.2013, 14:15 GMT-4
Naveet-
You have no displacement boundary condition in the x-direction. For some reason, the solver still found a stationary solution even though you have not constrained the rigid body motion in the x-direction.
If you add a displacement condition in the x-direction on the point in the center of the beam you will get symmetry in the displacement solution.
See attached file.
Josh Thomas
AltaSim Technologies
Naveet- You have no displacement boundary condition in the x-direction. For some reason, the solver still found a stationary solution even though you have not constrained the rigid body motion in the x-direction. If you add a displacement condition in the x-direction on the point in the center of the beam you will get symmetry in the displacement solution. See attached file. Best regards, Josh Thomas AltaSim Technologies
