Problem with interpolation function and variable
Hi !
I'm a beginner in COMSOL 4.2a and I'm trying to simulate a model using the Microwave Heating interface.
I have to consider the temperature dependance for the thermal conductivity and the electrical conductivity.
For now, I just create an interpolation function, named "func1", which has only one argument (temperature)
and giving the corresponding thermal conductivity.
I also define a variable "var1" to create a link with the function, and I use it as a value of the thermal conductivity.
But after simulation, I get this message :
Failed to evaluate variable Jacobian
- Variable : T
- Geometry : 1
- Domain : 1
The domain 1 is a material using the variable "var1" as thermal conductivity.
Does anyone know how to solve this problem ? Thanks in advance.
Nicolas.
2 Replies Last Post 11.07.2013, 08:15 GMT-4
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 11.07.2013, 04:03 GMT-4
I can see two problems here:
- The dependent variable name for temperature in the Microwave Heating physics is T2 and not T (probably because the model at some point included some other heat transfer physics that defined a temperature T). You can rename T2 as T under Dependent Variables in the Microwave Heating node's settings window.
- The variable var1 is defined as a global variable, where T is not recognized as the variable for temperature because it is defined as a temperature field in the geometry in Model 1. If you instead define the variable under Model 1>Definitions, it will recognize T and you will not see the orange color that indicates a problem with the variable (the tooltip says "Unknown variable T"). It is possible to refer to T also on the global level, but you must then use the syntax mod1.T.
Magnus Ringh, COMSOL
Hi, I can see two problems here: - The dependent variable name for temperature in the Microwave Heating physics is T2 and not T (probably because the model at some point included some other heat transfer physics that defined a temperature T). You can rename T2 as T under Dependent Variables in the Microwave Heating node's settings window. - The variable var1 is defined as a global variable, where T is not recognized as the variable for temperature because it is defined as a temperature field in the geometry in Model 1. If you instead define the variable under Model 1>Definitions, it will recognize T and you will not see the orange color that indicates a problem with the variable (the tooltip says "Unknown variable T"). It is possible to refer to T also on the global level, but you must then use the syntax mod1.T. Best regards, Magnus Ringh, COMSOL
Posted: 1 decade ago 11.07.2013, 08:15 GMT-4
Hi !
Thank you very much, this solves my problem. Now it's working !
Nicolas.
Hi ! Thank you very much, this solves my problem. Now it's working ! Best regards, Nicolas.
