16.03.2010, 18:42 GMT-4
Hi Amit,
Modal analysis cannot be used to estimate displacements. It is a method to extract the natural frequencies only. The displacements shown depend on the method used for normalization. If you want displacements, you would have to do a harmonic analysis by applying the appropriate loads.
Mihir
Hi Amit,
Mihir
17.03.2010, 03:32 GMT-4
Yes indeed amplitudes in frequency analysis of COMSOL should be seen as relative items, unitless
In anycase, for modal analysis, amplitudes depends on the quality factor Q that is directly coupled to the loss or damping values you use, therefore either you know the losses and you get correct absolute values (relative they will anyhow be OK), or you measure your damping factor via the resonance heights versus half widths values and you run a parametric sweep (or an optimisation) of your damping factor on your model to identify how to match both.
What you can find out though, with an eigenfrequency calculation, is the relative participation factors of the different modes, and how much relative energy there are in the different ones.
This is not directly derived by COMSOL, as you have it in Nastran, Ansys, COSMOS and most others FEM tools, because COMSOL uses a different eigenfrequency normalisation. But you can, if your model is not to heavy, export the matrices into matlab and normalise them ther.
Take a look at :
www.comsol.com/community/forums/general/thread/2650/
for the litterature you have good descriptions in "Actrive Control of Structure", A. Preumont and K Seto, Wiley, 2008, chapter 1.
By the way Prof. A. Preumont (Springer, and Kluever) has some very interesting books with good examples to run in COMSOL on Piezo structures and control thereof
Have a nice reading and
Take a look at :
http://www.comsol.com/community/forums/general/thread/2650/
17.03.2010, 06:00 GMT-4
Eigenfrequency analysis only gives you modes, but not displacement. It is the basic of mechanics.
17.03.2010, 06:07 GMT-4
Ivar, do you know how to describe complex eigenfrequency in COMSOL? And thanks for recommending the book, fortunately I have found it in the library :-)
17.03.2010, 09:02 GMT-4
Well complex values eigenmodes/frequencies should be linked to damping in structural, and in comsol its the "phase" variable that represents the complex "i", try an indexed search on your doc with "phasor variable" and start in the guide.pdf
But I beleive that in structural, the complex mode is not "on" by default, pls check your solver settings, but it might implicitely turn on with the definition of a damping <> 0
But I beleive that in structural, the complex mode is not "on" by default, pls check your solver settings, but it might implicitely turn on with the definition of a damping 0
