Export water table time series data from periodic Richards equation solution
Posted 23.06.2013, 00:05 GMT-4 Results & Visualization, Studies & Solvers Version 4.3, Version 4.3b 2 Replies
is there an (easy) way to export a time series of the water table elevation (p=0 contour) from a time-dependent (periodic) Richards equation model?
I have a 2D vertical rectangular grid with a periodic boundary condition at one end which drives a pressure wave through the porous media domain and I would like to analyse the characteristics of the water table fluctuations as a function of x and t. At present, I am using mphinterp via the Matlab interface to access the spatio-temporal grid of the pressure distribution from the solution and then interpolating using Matlab to find the watertable, wt(x,t). This is a bit cumbersome and I am wondering if it can be generated as part of the Comsol result processing? It seems I can only export the p=0 contour for a single time step (?)
Any ideas would be appreciated.
Cheers,
Nick
Cheers,
Nick
2 Replies Last Post 28.06.2013, 21:28 GMT-4
