Pre stressed frequency domain analysis - How to: Values of Dependent variables
Posted 17.06.2013, 08:45 GMT-4 Studies & Solvers, Structural Mechanics Version 4.3b 3 Replies
I am trying to use the solution of the static deformation as the initial conditions for my frequency response analysis.
First, I have prepared two solutions, the static deformation is calculated in a stationary step. The frequency response is calculated in the frequency domain. And under the frequency domain solver, the Values of Dependent variables were taken from the static solution, at least I think I am doing it so.
When the solver finishes calculating, the results indicate no sings of the static solution as if the frequency domain was calculated independently from the static solution.
Secondly I tried using the Preset Studies: "Pre-stressed Analysis: Frequency Domain" with no success.
From the documentation it seems so straight forward to implement this and I feel that I am missing something fundamental.
Can somebody comment on the attached file? Or which example do you recommend for me to examine?
Thanks in advance,
Onur
Thanks in advance,
Onur
3 Replies Last Post 04.05.2016, 14:52 GMT-4
