Assigning a sinusoidal electric potential to a boundary
I am relatively new to COMSOL and I am building a transformer model for use in researching different hysteresis losses and associated heat energy with using different core materials. I have built a geometric model of the device. I am trying to assign an electric potential to one end of the primary winding on the transformer (the other end will be ground). I can give it a DC potential, but I want to assign a sinusoidal waveform to the voltage across the primary winding. How can I do this?
I included the Electric Currents physics engine and I defined a waveform for the primary coil voltage, but that is all the further I have gotten. I feel like if I could just define the "Equation" setting in the Electric Potential phenomenon under the "Electric Currents" physics, it would allow me to specify a sine wave potential.
I would really appreciate any input.
5 Replies Last Post 13.05.2013, 11:41 GMT-4
Posted: 1 decade ago 13.05.2013, 10:18 GMT-4
I can help you if you are working in the time domain?
R
I can help you if you are working in the time domain? R
Posted: 1 decade ago 13.05.2013, 10:46 GMT-4
Yes, I am working in the time domain.
Posted: 1 decade ago 13.05.2013, 11:06 GMT-4
This example I created should tell you how to do it.
The model is acoustic so you may not be able to use it.
But I choose a point or boundary and in the 'Pressure' I type...
5*sin(2*pi*f0_air*t)*(t<=2*t_pulse)
5 is the magnitude
fo_air is the frequency of the oscilation (Hz)
t is the Comsol variable for time
and
t_pulse is the duration of the cycle (1/frequency)
Just make sure that your time steps are sufficiently small to model a given frequency. I find that a CFL of 0.05 is good.
Let us know if you dont know what the above means.
This example I created should tell you how to do it. The model is acoustic so you may not be able to use it. But I choose a point or boundary and in the 'Pressure' I type... 5*sin(2*pi*f0_air*t)*(t
Posted: 1 decade ago 13.05.2013, 11:37 GMT-4
Yes, what does CFL refer to?
What is the purpose of specifying the time step?
As a COMSOL variable, 't' is already defined?
Yes, what does CFL refer to? What is the purpose of specifying the time step? As a COMSOL variable, 't' is already defined?
Posted: 1 decade ago 13.05.2013, 11:41 GMT-4
I dont have time to go through time stepping in FEA for you. This will be covered in most FEA books that deal with dynamics or explicit solvers.
I suggest you do the Gaussian explosion example in Comsol. This will teach you about time stepping and CFL condition.
good luck
I dont have time to go through time stepping in FEA for you. This will be covered in most FEA books that deal with dynamics or explicit solvers. I suggest you do the Gaussian explosion example in Comsol. This will teach you about time stepping and CFL condition. good luck
