Swept mesh density dependent of a spatial function
Dear all,
I have a simple question: how can I define in swept mesh a function (spatial) of refinement? Just for example, I have a strip and I would have a very fine mesh only in the middle.
I have tried in this way: I set a parabolic function in Definitions>Analytic, 0.8+x^2 (supposing x is the direction of the swept), and then I inserted the function in Swept>Size>Max Element Size, hence an1(x). In this way I should get element of max 0.8 in the middle of the strip, and bigger going towards the sides.
But it seems that Comsol does not accept functions in element size parameters. What I am doing wrong?
Thank you very much
Fabio
3 Replies Last Post 06.05.2013, 15:07 GMT-4
Posted: 1 decade ago 06.05.2013, 11:57 GMT-4
use the dimensions node, but the best I know bout is to "cut" up your geometry by ading some internal boundaries, it helps for selecting and probing too
Hi use the dimensions node, but the best I know bout is to "cut" up your geometry by ading some internal boundaries, it helps for selecting and probing too -- Good luck Ivar
Posted: 1 decade ago 06.05.2013, 13:03 GMT-4
Hi Ivar,
thank you for your reply. Yes I already know the solution to cut up domains, faces and edges and assign a respective size. I was wondering if there was some "analytical" solution...it's strange that Comsol does not accept a function in the size parameters...
A problem can come out if I have a function not only spatial but also time dependent, thus refining a mesh in a zone that "moves" with time, what a Gaussian Pulse can do (for instance, if a have a heat source that moves with time). How can I deal with this requirement?
Thank you again for any suggestions
Fabio
Hi Ivar, thank you for your reply. Yes I already know the solution to cut up domains, faces and edges and assign a respective size. I was wondering if there was some "analytical" solution...it's strange that Comsol does not accept a function in the size parameters... A problem can come out if I have a function not only spatial but also time dependent, thus refining a mesh in a zone that "moves" with time, what a Gaussian Pulse can do (for instance, if a have a heat source that moves with time). How can I deal with this requirement? Thank you again for any suggestions Fabio
Posted: 1 decade ago 06.05.2013, 15:07 GMT-4
I believe that in the "dimensions node" you can define on edges, accept field variables but you need to trigger the remeshing somehow.
You can also "box mesh refinement", probably there too with variables (to be checked)
Iva
Hi I believe that in the "dimensions node" you can define on edges, accept field variables but you need to trigger the remeshing somehow. You can also "box mesh refinement", probably there too with variables (to be checked) -- Good luck Iva
