acceleration due to gravity Laminar flow
I want to give acceleration due to gravity effects to fluid in Laminar pipe flow, any one know how to give,?????
I have tried by applying domain volume force like 9.81*density of fluid but i am not sure it is right ???
any suggestions??
2 Replies Last Post 01.05.2013, 03:29 GMT-4
Posted: 1 decade ago 01.05.2013, 02:20 GMT-4
what is wrong by adding a "body force" like that ? use the internal "g_const" for the gravity acceleration see help "physical constants"
but think of your model i.e. in 2D-axi you can only simulate gravity along the vertical +/- Z direction, as otherwise you add a radial force, hence you are in a special rotating tube case
un CFD still you have also the pressure build-up with height (along gravity vector direction as Dp = g_const*rho*(z-z0)
COMSOL acts on the infinitesimal element volume dx*dy*dz so if you multiply
integral_over_domain g_const*rho*dx*dy*dz you get to the force in Newton [N=m/s^2*kg/m^3*m*m*m ]
Hi what is wrong by adding a "body force" like that ? use the internal "g_const" for the gravity acceleration see help "physical constants" but think of your model i.e. in 2D-axi you can only simulate gravity along the vertical +/- Z direction, as otherwise you add a radial force, hence you are in a special rotating tube case un CFD still you have also the pressure build-up with height (along gravity vector direction as Dp = g_const*rho*(z-z0) COMSOL acts on the infinitesimal element volume dx*dy*dz so if you multiply integral_over_domain g_const*rho*dx*dy*dz you get to the force in Newton [N=m/s^2*kg/m^3*m*m*m ] -- Good luck Ivar
Posted: 1 decade ago 01.05.2013, 03:29 GMT-4
Thanks alot Ivar, my problem is 3D and i think your help worked me
