29.04.2013, 02:17 GMT-4
first of all is it a transient time analysis, or a steady state ? If the latter I would recommen to use a frequency domain study, it solves far quicker.
Then what exactly are you needing in the temperature domain ?
Is it a fixed temperature you want to impose or a temperature ananlysis w.r.t. absorption and stress / strain work ?
If you want to impose a temperature, then add a sub node to your linear material with a temperature dependce, define the rest equilibrieum temperature Tref, and make a parametric sweep over the fixed temperature T that you impos
29.04.2013, 07:49 GMT-4
Hi Ivar, many thanks for the advice. I will answer your question by topics.
- the heating model needs to be trasient.
- I need the temperature evolution in the sample.
- I can make the material properties (dielectrics) vary with the temperature with an interpolation function.
- I can make the frequency vary in time, by making a global interpolation function writing in study-step1-frequency: freq_time_frit(t)
- But what I require is to impose a dependency of temperature in a function freq_temp_frit(??), I do this because the resonance frequency changes with the material temperature. The material has high "k" so the temperature is almost contant. I tried to put the result of one of my probes (domain point probe) - ppb1 in the freq_temp_frit function. And give a big error message saying that couldn't determinate the frequency and related variables. Any suggestion?
- Since I am studying different input powers in waveguide I need to use the function with the temperature.
Kind Regards,
Duarte Albuquerque
Kind Regards,
Duarte Albuquerque
29.04.2013, 08:05 GMT-4
you have (in v4.3a) also the frequency transient and frequency stationary solvers, for given cases (particularly in RF)
02.05.2013, 13:46 GMT-4
Hi Ivan.
I defined two function one freq_vs_time() and freq_vs_temperature().
If I put in the frequency-transiente study, in the field frequency: freq_vs_time(t) - I obtained the results with the frequency variation in time quite well.
How can do the same with the freq_vs_temperature? How it is the argument tempeture use here? I can use the value of a probe or the average temperature in the sample. I don't know how to put the temperature as an argument here. Any clue?
Thanks in advance,
Duarte Albuquerque
Hi Ivan.
Thanks in advance,
Duarte Albuquerque
