Animation depending on distance
Hello dear Comsol gurus,
I have made a CFD simulation (stationary) which is based on the model library example of the static mixer. I have also generated the slices and surfaces to see how my fluids are being mixed (using concentration results) but I would like to make an animation with them.
Is there a way to make an animation using the slices (or surfaces)? This animation then would depend on the distance (on x for example) and not on time.
Thank you in advance
Best regards
Miguel
3 Replies Last Post 09.04.2013, 14:17 GMT-4
Posted: 1 decade ago 09.04.2013, 08:26 GMT-4
Try the following:
- Global Definitions > Parameters: Add a parameter that denotes the plane's position. Let's call it x_plane.
- Results: Add a 3D plot group, and add a slice plot to the plot group.
- In the slice plot: Set entry method to Coordinates and x-coordinates to x_plane.
- Results > Export: Add a Player.
- In the Player: Set Sequence type to Result Parameter, Parameter to x_plane, and enter the values that you want to vary x_plane between in the Start and Stop fields, respectively.
- Play.
[QUOTE] Is there a way to make an animation using the slices (or surfaces)? This animation then would depend on the distance (on x for example) and not on time. [/QUOTE] Try the following: - Global Definitions > Parameters: Add a parameter that denotes the plane's position. Let's call it x_plane. - Results: Add a 3D plot group, and add a slice plot to the plot group. - In the slice plot: Set entry method to Coordinates and x-coordinates to x_plane. - Results > Export: Add a Player. - In the Player: Set Sequence type to Result Parameter, Parameter to x_plane, and enter the values that you want to vary x_plane between in the Start and Stop fields, respectively. - Play.
Posted: 1 decade ago 09.04.2013, 09:06 GMT-4
Dear Mr. Andersson,
thank you very much for your answer, the animation was succesfully created!.
Best regards
Miguel Terán
Dear Mr. Andersson, thank you very much for your answer, the animation was succesfully created!. Best regards Miguel Terán
Posted: 1 decade ago 09.04.2013, 14:17 GMT-4
check the export animation tab and related help, ay parametric sweep (incl time sweep) can be exported as an animation, from my understanding
Hi check the export animation tab and related help, ay parametric sweep (incl time sweep) can be exported as an animation, from my understanding -- Good luck Ivar
