Parametric sweep
Constantinos Tsangarides
I have a range of angles set as parametric sweep ie range(0[deg],0.1[deg],4[deg])
And also I have a study in frequencies with range(2[THz],0.1[THz],5[THz])
When it solves it puts them all together in one table.
I want to plot graphs with absorption at each angle for the above range of frequencies.
i.e. one graph at 0[deg], another at 0.1[deg] etc
But when I try to plot them it plots all ranges together in a messed graph.
I tried to select only one angle but again I still get an even messier graph.
Can somebody help me with this?
1 Reply Last Post 08.04.2013, 11:59 GMT-4
Posted: 1 decade ago 08.04.2013, 11:59 GMT-4
it depends also on how you have selected the parametric sweep sequence (full combination or not) normally you et a table with lines and columns like that you can switch them and select only a few, but this selection is reset at each study run.
I believe its shown in one of the postprocessing videos on the main site
Hi it depends also on how you have selected the parametric sweep sequence (full combination or not) normally you et a table with lines and columns like that you can switch them and select only a few, but this selection is reset at each study run. I believe its shown in one of the postprocessing videos on the main site -- Good luck Ivar
