set path of the external matlab function
Hello all,
I am trying to run a Matlab script of my model which in turn uses an external Matlab function. When I run the model from matlab, comsol opens a new Matlab process and tries to call the function. the problem is I am not able to explicitly specify the path of the function being called.
I did add the function's path to Matlab path, but it somehow does not get updated in the new process that comsol opens internally.
Going through Java API documentation, I found that it is possible to set the path of the function using
model.func.create('extm1', 'MATLAB');
model.func('extm1').set('funcs',{<functionname>,<argslist>});
model.func('extm1').set('manpath',<path>)
This however, does not seem to work from Matlab. Any ideas, suggestions?
Also, when I copied the function in Matlab's default path (/home/user/Documents/MATLAB), the script works just fine, it only doesnt work when the path is not default
1 Reply Last Post 27.03.2013, 04:07 GMT-4
Remi Magnard COMSOL Employee
Posted: 1 decade ago 27.03.2013, 04:07 GMT-4
Dear Jyani,
To set up the function directory path in MATLAB you have three options:
- save the model (in the MPH format) in the same directory as the for the M-functions. In case you set up the model in a M-file, you can still save the model object before running the study. To proceed add the command:
model.save(fullfilename);
- Set the system environment variable COMSOL_MATLAB_PATH with the M-functions directory path.
- Use the Set Path window available in the MATLAB desktop (MATLAB Home ribbon > Environment group). Adding the MATLAB path (with ADDPATH) does not as you the external MATLAB function is evaluate in a separate MATLAB process.
The JAVA API reference guide refers to an obsolete properties, sorry for the confusion.
Rémi Magnard
Dear Jyani, To set up the function directory path in MATLAB you have three options: - save the model (in the MPH format) in the same directory as the for the M-functions. In case you set up the model in a M-file, you can still save the model object before running the study. To proceed add the command: model.save(fullfilename); - Set the system environment variable COMSOL_MATLAB_PATH with the M-functions directory path. - Use the Set Path window available in the MATLAB desktop (MATLAB Home ribbon > Environment group). Adding the MATLAB path (with ADDPATH) does not as you the external MATLAB function is evaluate in a separate MATLAB process. The JAVA API reference guide refers to an obsolete properties, sorry for the confusion. Best regards, Rémi Magnard
