Save soltution at stop condition
Hi!
How can I force COMSOL to save the solution for the time instant when the stop condition is satisfied?
Thank you,
Miroslav
1 Reply Last Post 15.03.2013, 01:29 GMT-4
Posted: 1 decade ago 15.03.2013, 01:29 GMT-4
you means save to file and exit, or save the results, I understood it did the latter. Check the batch and extra solver nodes for runand close, I believe there is something, but that I havent tried, usually for long runs, I leave it over night and find my results for the coffee (except when MS has decidedd to update and reboot, then I loose my work if the "recovery" has not worked
Hi you means save to file and exit, or save the results, I understood it did the latter. Check the batch and extra solver nodes for runand close, I believe there is something, but that I havent tried, usually for long runs, I leave it over night and find my results for the coffee (except when MS has decidedd to update and reboot, then I loose my work if the "recovery" has not worked -- Good luck Ivar
