First time user - Which Model to use
I am trying to model a particle moving through the air via gravity and impacting a liquid and getting imbedded into a glue like liquid.
Is this a CFD model or a mechanics model? Are there any tutorials or models to learn this type of model?
Many thanks,
1 Reply Last Post 07.03.2013, 15:45 GMT-5
Posted: 1 decade ago 07.03.2013, 15:45 GMT-5
you will probably have to check the level set of CFD models, or some FSI ? but if your "particle is a solid" and you want to see it deform its a mixture, else you can probably get around only within CFD and the pre-cooked modles.
Have you checked the model library ? there should eb an example of a ball falling in a fluid, in a tube (but you hae no free fall before hitting the fluid I believe)
Hi you will probably have to check the level set of CFD models, or some FSI ? but if your "particle is a solid" and you want to see it deform its a mixture, else you can probably get around only within CFD and the pre-cooked modles. Have you checked the model library ? there should eb an example of a ball falling in a fluid, in a tube (but you hae no free fall before hitting the fluid I believe) -- Good luck Ivar
