Grain Modeling
In ComSol 4.2 how can we give different crystal to different grains Please suggest any method , as I am able to change crystal orientation of whole model but not of each boundary unit separately.
Please guide me with it.
3 Replies Last Post 18.03.2013, 15:04 GMT-4
Posted: 1 decade ago 27.02.2013, 04:35 GMT-5
you need to define a coordinate per "domain" so if you have N "grains" you need N domains and either N coordinates, or a random function and an general expression reproducing the N changes for the N domains
I do not see any other way, if I have interpreted your question correctly ;)
Hi you need to define a coordinate per "domain" so if you have N "grains" you need N domains and either N coordinates, or a random function and an general expression reproducing the N changes for the N domains I do not see any other way, if I have interpreted your question correctly ;) -- Good luck Ivar
Posted: 1 decade ago 18.03.2013, 11:52 GMT-4
Hi Ivar
I have to import an Image to a 2D file and than pursue an extrapolation to 3D.
Can you please guide me with the same.
Regards
Yash
Hi Ivar I have to import an Image to a 2D file and than pursue an extrapolation to 3D. Can you please guide me with the same. Regards Yash
Posted: 1 decade ago 18.03.2013, 15:04 GMT-4
in COMSOl 3D you can ad a workplane and import a 2D file format into this workplane, then extrude that in the Z directin (all to the same height though). Check which 2D file format your version of COMSOl can accept
Hi in COMSOl 3D you can ad a workplane and import a 2D file format into this workplane, then extrude that in the Z directin (all to the same height though). Check which 2D file format your version of COMSOl can accept -- Good luck Ivar
