About creation of struturegeomerty
Hi...!
I am a student of University of Pune,working on Rf MEMS Switch. I can't get how to create a structural geometry of cantilever beam in Com sol multiphysics.
So please help me to create a geometry.
uhyadav
5 Replies Last Post 16.04.2013, 05:58 GMT-4
Posted: 1 decade ago 21.02.2013, 01:54 GMT-5
if you are stating with COMSOL, I can only recommend to start in 2D, then later move to 3D once your model is running, particularly when mixing several physics. For a cantilever you draw it simply with a rectangle (I suggest to split in two by the middle with a geometry layer setting at half the height to force 2 mes elements per thickness, minimum), then fix one end and run i.e. an eigenfrequency study
Hi if you are stating with COMSOL, I can only recommend to start in 2D, then later move to 3D once your model is running, particularly when mixing several physics. For a cantilever you draw it simply with a rectangle (I suggest to split in two by the middle with a geometry layer setting at half the height to force 2 mes elements per thickness, minimum), then fix one end and run i.e. an eigenfrequency study -- Good luck Ivar
Posted: 1 decade ago 27.02.2013, 00:02 GMT-5
Thank you very much for your valuable help.
uhyadav
Thank you very much for your valuable help. -- uhyadav
Posted: 1 decade ago 09.04.2013, 02:56 GMT-4
I have problem with how to analyses the various physics for RF MEMS switch.
uhyadav
I have problem with how to analyses the various physics for RF MEMS switch. -- uhyadav
Posted: 1 decade ago 09.04.2013, 14:24 GMT-4
you need to explain a bit more for us out here to understand, have you looked at the different webinars videos on the main COMSOL site ? such as
www.comsol.eu/video/
Hi you need to explain a bit more for us out here to understand, have you looked at the different webinars videos on the main COMSOL site ? such as http://www.comsol.eu/video/ -- Good luck Ivar
Posted: 1 decade ago 16.04.2013, 05:58 GMT-4
This my .mpd file using comsol4.1,please help me for adding physics for simulation of this geometry. For this use electrostatics as a physics.
uhyadav
This my .mpd file using comsol4.1,please help me for adding physics for simulation of this geometry. For this use electrostatics as a physics. -- uhyadav
