2 decades ago
28.02.2010, 03:10 GMT-5
hello,
The error, Failed to find consistent initial values, has been dispeared by modifying boundary conditions.
But 'error in residual computation' arose. maybe I need to fit the value of parameters.
The error, Last time step is not converged, is still there.
hello,
2 decades ago
16.03.2010, 16:30 GMT-4
I am experimenting similar issues.
My error message is following.
Did you solve your previous issue? If so, I could be interested how you did.
I am also a new user, an advice would be more than welcome.
Don't hesitate to contact me if you need additional informations, thanks in advance.
Yannick
Error:
Time 1935360:
Error in residual computation.
Power_of_negative
Function: ^
Failed_to_evaluate_variable
Variable: dwdH, Defined_as: ((-((c^(delta-1))*(phi*(phi*(delta*beta)))))/((1+((phi*beta)*((c^delta)-1)))^2))
Variable: Dts_c_di, Defined_as: dwdH
Failed_to_evaluate_expression
Expression: d(((-D_c_di*cx*test(cx))-(Dts_c_di*ct*test(c)))*(dvol),{test@1})
Yannick
[quote] Error:
Time 1935360:
Power_of_negative
Function: ^
Last time step is not converged.[/quote]
02.06.2010, 11:12 GMT-4
I am a new user and having the same problem. If i refine my mesh the error takes longer to appear. I am not sure what this means except it is an error in convergence since my value being raised to the exponent should never be negative. I am assuming that if you put a logical statement somewhere to prevent this it should be cured.
Alex
Alex
19.04.2011, 12:02 GMT-4
I am a new user.I am also having the same problem,If u resolved the problem before,please help me to get right...
My error code is
Time 3.746334577378822:
Power_of_negative
Function: ^
Variable: i0, Defined_as: (((k_pos*((c1max_pos-c1s_pos)^aA_pos))*(c1s_pos^aC_pos))*(c2^aA_pos))
Variable: i_loc, Defined_as: ((exp((((Far*aA_pos)*eta)/(Rg*T)))-exp(((((-aC_pos)*Far)*eta)/(Rg*T))))*i0)
Expression: d(((-K1eff*phi1x*test(phi1x)/L_pos-i_loc*Sa_pos*L_pos*test(phi1))-(0))*(dvol),{test@1})
Rajesh
My error code is
Power_of_negative
Function: ^
Rajesh
