show the field lines around a magnet
Hi.
How can show the field lines around a magnet?
Thank.
1 Reply Last Post 17.02.2013, 11:41 GMT-5
Posted: 1 decade ago 17.02.2013, 11:41 GMT-5
you go under your plot and add the field line sub-node, define the field you want B (default normally), or H ... and then set the density distribution, if required
Hi you go under your plot and add the field line sub-node, define the field you want B (default normally), or H ... and then set the density distribution, if required -- Good luck Ivar
