Trouble finding the electrostatic force
I am very new to comsol and I am running into some trouble while trying to calculate the electrostatic forces in my model. The model I'm analysing is a comb drive. I made a very basic 2D model in order to check first whether I could find the force based on only a static es simulation but I'm already running into trouble. I really just need to find the total reaction force between the two objects but when I try to plot or calculate the force it doesn't show up.
Any help would be much appreciated.
Greetings, Mick.
1 Reply Last Post 12.12.2024, 10:27 GMT-5
Posted: 2 weeks ago 12.12.2024, 10:27 GMT-5
Hi Mick,
you must add a Force Calculation subnode for the domain you want the force. Make sure the mesh is fine enough where field gradients are high.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Mick, you must add a Force Calculation subnode for the domain you want the force. Make sure the mesh is fine enough where field gradients are high. Cheers Edgar
Reply
